It sounds like you are ready for a new faucet.
OK here we go my cold water was dripping so I took it off to replace the washer and then I saw that the Faucet Seat was just sit in the pipe so I tried to put it back in the threads and they are all broke so I cant put the seat back in
WHAT should I DO NOW
either call a plumber who has a set of taps so he can install a different sized seat, or replace the faucet.
so what I have to do is cut the other side of the wall and replace the hole thing or is there an easy way
Go to a pro plumbing supply house and look for shower faucets with extra large estucheon plates made for the purpose of going into the wall from the shower side to replace the faucet. The large estucheon plates will cover the larger hole necessary to remove the old and install the new faucet.
Just ask, and they will know what you need.
Good Luck!
Mike
