Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Dirty well water
  1. #16
    Well driller,pump repair. and septic installer Waterwelldude's Avatar
    Feb 2009
    Texas
    It is so sad to read that a so called driller will not come back and do his job.
    A driller is paid to get you usable water(hopefully drinkable), and yet after hes gone. There is dirty water coming out the tap.
    To give a costumer clean water IS the drillers job. If someone wants dirty water, all they have to do is go to a ditch after a rain and get a glass of dirty water.
    You should call the driller back, and show him the dirty water, and ask him why its dirty, and how can he fix it..
    "I shall never surrender or retreat" -Col. William Travis
  2. #17
    Well Drilling/Service justwater's Avatar
    May 2010
    NE FL, SE GA
    around here one could contact the local water management district and talk to the head of well construction for the area. those are the guys that issue/revoke drilling licenses. bad it should come to that, but apparently your driller needs a reality check. he needs to make good.
  3. #18
    Moderator valveman's Avatar
    Mar 2006
    In our area we use really small gravel to gravel pack the well. This filters out the sand and sediment before it enters the well casing. If I couldn't clear it up in a day or two, I would be over drilling you a new well for free, because I apparently didn't get the gravel pack right.
  4. #19
    DIY Junior Member Ichabod's Avatar
    Jan 2010
    Statesboro, GA
    I live in SE Georgia, above the Floridan aquifer. We have deep wells into that for our water. I have watched them drill and service pumps here and what they do before installing the pump is run a pipe to the bottom of the well, we're talking about 300 feet or so, and connect a big air compressor, like a jackhammer compressor, to it and blow it out. You wouldn't believe the black mess that comes out of an old well when they replace the pump. After that the water is crystal clear.
