SepticTankTech
We live on a rural property in Canada. Our septic tank is located about 6 ft from the house, and about 10 ft from the toilet. Our toilet is a conventional 3-gal American Standard model, approximately 10 years old.
Periodically, toilet paper builds up at the inlet to the septic tank, causing a blockage. (This most often happens with a house full of guests!) Plunging the toilet has no effect. The only way to clear the blockage is to open the septic tank and clear the blockage at the inlet. I have made a clean-out tool out of copper pipe which works well. Usually, the blockages are easy to clear.
The drain pipe does not appear to have any obstructions and I haven't found any evidence of root growth. Both house and tank are about 30 yrs old, and I am wondering if settling has resulted in a small uphill slope to the drain pipe which slows the flushed material and causes a blockage when there is too much paper, etc.
Would a Gerber pressure-assisted toilet move the flushed material down the drain pipe faster, and thereby help to keep the pipe clear? Is there something else I should consider? I would like to avoid having to dig up the septic tank if at all possible.
Reluctant Septic Tank Technician
