setherd
- Messages
- 3
- Reaction score
- 0
- Points
- 0
OK I spent most of the day fixing what I thought was a toilet leak only to find out it's related to my tub.
My fiancée used the shower and when she got out she yelled that there was water all over the floor. I discovered water coming up from the toilet mounting bolts. I figured the seal had to be broken. I took the toilet off and found some paper across the wax seal- not sure how that got there.
one side of the closet flange was broken. The closet flange is cast iron and part of the drain pipe. After trying to replace the closet flange I gave up and put a new wax ring down and used the remaining good bolt to hold the toilet. it doesn't wiggle but the side without a bolt sits a little higher than the other. I caulked around the edge.
(this part was described to me over the phone- i'm at work)
No leak until she filled the tub up. When it drained (slowly) water came out from the seal at the base of the toilet.
my guess is that I have a partial obstruction somewhere in my drain line after the toilet and shower line meet. small amounts of water like a toilet flush can go thru but when the tub or shower drains it backs up.
BUT.... why does it leak at the toilet base? I thought with the wax seal (if it's on correct) would stop it. If anything the tub or toilet bowl should back up right?
any comments, ideas, etc would be appreciated!
thanks!
Seth
thanks!
Seth
