Page 4 of 8 FirstFirst 12345678 LastLast
Results 46 to 60 of 118
Thread: Tankless info from consumer reports, Tankless...Bahhhhh
  1. #46
    This morning I measured the flow rate of my shower head with the flow rate set to full on. My shower head is indeed a 2.2 gallon per minute shower head. I just set the volume knog in the shower to the flow rate that feels comfortable. That comfortable flow rate is about 1 gpm,and about 1/3 of the water is from the cold valve.
    I would not be surprised if I could run two simultaneous showers even with the current low 40 degree incoming water temperature. I will test that after I get my second shower finished up.
    Obviously, some people do not like "low flow" shower heads. They require something more like the Commando 450!
    http://www.youtube.com/watch?v=dlrtQ...eature=related
    The IPC commisioned a study about the flow rate required to take a shower. They found it hard to complete the study.
    http://www.youtube.com/watch?v=hUoyb...eature=related
  2. #47
    Master Plumber nhmaster's Avatar
    Jul 2008
    S. Maine
    Die Die Die Please God just Die!
  3. #48
    DIY Senior Member WV Hillbilly's Avatar
    Aug 2008
    WV
    Exactly what I've been thinking about the whirlpool water heater thread !!!!!!!!!!!!!!
  4. #49
    Plumbing Contractor C NUMB's Avatar
    Jan 2009
    NPR, FL
    Quote Originally Posted by nhmaster View Post
    When will this topic just DIE.
    I will sum up tankless water heaters;
    Expensive to buy
    Expensive to have installed
    Somewhat less expensive to operate
    May not produce enough hot water
    Work better in warmer climates
    Work better with good water conditions
    May not meet code in all localaties (remember the code does say that you have to provide hot water to all fixtures in the home)
    Require regular service
    Cause heated arguments that never ever seem to end.
    I agree with the above quote with the exception of them working better in a warmer climate- No they don't!!
  5. #50
    Radon Contractor and Water Treatment 99k's Avatar
    Aug 2008
    Fairfield Co.,Connecticut
    Ok I waiting for my electric water to die and it won't ... so I'm going to bring it behind the barn and shoot it. We have a 45 yr/old furnace so I don't feel like creating hot water from the furnace. I am convinced I do not want a tankless. What about the stand alone gas heaters with a power ventilator? We don't have gas so I'd have to get a 100 gallon tank of propane. Does this option make sense and if so can you recommend a good brand. Thanks.
  6. #51
    Jul 2008
    S. Maine
    Quote Originally Posted by C NUMB View Post
    Love you man.
  7. #52
    Nov 2008
    Chicago, IL
    Oh you can make them work great, if you put in more than one.
  8. #53
    Expensive to buy
    #1 Bought my Rinnai r74lsi for $675 +$150 for vent pipe. Subtract $300 fed tax rebate.
    #2 Installed myself.... I can do good DIY !
    #3 Yep, didn't really care about cost SAVINGS but did get some.
    #4 FALSE, damn lies too! All the hot water I want for a family of 6...Fact!
    #5 Live in NE Texas, good inlet water temps. I don't live north of MD line and life is good.
    #6 No code issue, Gas company rep was drooling over it!
    #7 Once a year. Own a vehicle and don't do routine service???
    #8 Only by a few.... "up north folks"
    Alternate hot water sources are here to stay. Being "green and energy efficient" will probably be mandated by the cmty for "change" that was just elected, like it or not.
    "Dude, we can fix that. My old man is a TV repairman, he's got the ultimate set of tools!" --Jeff Spicoli
    http://web.me.com/greg.saulsbury/ChosatongaSpeaks
  9. #54
    Jan 2009
    NPR, FL
    gregsauls, you got a deal on that unit, around here they start at 1100. By the time you are done it is usually around $1600 installed with permit as long as you already have gas, if not it is closer to $2400.
    BTW, I looked at your install on your blog, nice job!
    I'd Rather Be FISHIN'
  10. #55
    Jul 2008
    S. Maine
    Hooray!
    I'm wrong yet again. (whips self while hanging head in shame)
  11. #56
    Thanks for the compliments! I did get a good deal from a local wholesale house a buddy of mine manages. Funny thing, "the bay of E" sellers were within a few $$ of the local price but having the backing of my buddy was worth it.
    It's not a question of being right or wrong on going tankless. What needs to happen is for some to realize that what works for some may not work for others and more importantly... vice-versa. Tankless isn't the answer for everyone situation or location, but the fact remains it DOES work... at least for some.
    So generic answers of "they suck" are highly biased and should be judged as such.
  12. #57
    Apr 2005
    gregsauls,
    You're the minority. The less than 1% that can do these required tasks like installing it, maintaining it.
    I talk for the 99% that don't, or CAN'T.
    And what happens when your house of 6 loses hot water because of a malfunction...???
    We already know; you're going to be the one on the phone to the 1-800 number, the rep who sold it to you, begging for overnight or same day air-shipment of parts that you "think" match the error code on the majic box on the wall.
    6 people without hot water for hours, days isn't what I want. The majority want hot water within hours of a call to a plumber, to have the right parts and not fetch them from across the globe.
    And what happens if you become disabled to work on that unit:
    You just forced your family to really pay out the nose for repairs, maintenance, upkeep. You won't live forever, that's a known fact.
    20 years from now when it's as common as a part at the local hardware store, yes. But right now it's a high risk for many, especially that buy the BS about the green way of life because point of use is a new word?
    Point of use has been around for a long time, it just got elevated to handle a whole house. Nobody discusses the excessive use of these since they can take a 30-400 minute shower. Let's not talk about that, those car wash showerheads and what not.
    EXCESS WITH AN EXCUSE.
  13. #58
    Jul 2008
    S. Maine
    I just can't resist... They Suck
    forgive me lord..
    That weren't funny
  14. #59
    Quote Originally Posted by RUGGED View Post
    gregsauls,
    I like being that special 1% "that can" !!!! Thank you for the compliment, seriously. I do not feel I put my family at "risk" installing a tankless in the least little bit. And quit honestly a scare tactic like that will keep people away from technology. If it fails, yes I will be on the phone for parts. Just the same way I would be at the big orange box store replacing a TANK water heater when it springs a leak.... lets only hope I am THERE when it does it and can do damage control.
    All dogs have fleas.... but it's still my dog to love!
  15. #60
    Apr 2005
    Quote Originally Posted by gregsauls View Post
    Good points taken, and yes, you should be proud that you can do this work yourself.
    I was just mentioning the time factor from malfunction-to-repair that has people without water for days with a tankless.
    That's why I mentioned that in 20 years that this problem will most likely be removed.
    It has to get down to availability, common product to be worthwhile, which takes time.
    As a plumber I can see myself getting hustled on these when they fail, when it comes to replacement.
    Customer will take the old one off, put the new one on the wall and my job will be the "hook up" part and they'll minimize the effort stating, "Well I already mounted the unit for ya, sheesh! "
    Oh yeah, I can get that done for ya, $40 and a gallon of milk please.
  1. Consumer Reports Recommended toilet, Gerber DF-21-318 a big Flop!
    By Terry in forum Toilet Forum discussions
    Last Post: 05-07-2013, 07:04 PM
  2. new tankless info from consumer reports
    By master plumber mark in forum Tankless Water Heater Forum
    Last Post: 11-23-2009, 04:24 AM
  3. Can we believe Consumer Reports?
    By geepondy in forum Toilet Forum discussions
    Last Post: 03-11-2007, 07:27 AM
  4. Eljer Aqua-Saver Consumer Reports best buy
    By jmcdev1 in forum Toilet Forum discussions
    Last Post: 08-30-2005, 02:31 PM
  5. Confused about TOTO and Consumer Reports
    By livingaboard in forum Toilet Forum discussions
    Last Post: 01-19-2005, 12:29 PM
