Page 3 of 15 FirstFirst 12345678910111213 ... LastLast
Results 31 to 45 of 220
Thread: Navien tankless
  1. #31
    Geologist sjsmithjr's Avatar
    Dec 2005
    Knoxville, Tennessee
    Quote Originally Posted by nhmaster View Post
    Is this device code approved because it presents a very real possiblity of cross contamination should the exchanger be breached.
    "Double-walled heat exchangers meet most local plumbing codes for potable water. Double-walled heat exchangers are covered by the Uniform Plumbing Code, Section 603.3.4; 1995 CABO (Council of American Building Officials) One and Two Family Dwelling Code, Section 3402.3.1; 1998 ICC (International Code Council) One and Two Family Dwelling Code, Section 3402.4.2.1; and the 2000 and 2003 ICC International Residential Code, Section P2902.4.2 - Heat Exchangers."
    At least that's what they tell us...
    -Sam Smith
    Licensed Professional Geologist - AL, TN, KY
  2. #32
    Default Tankless Hot Water Heaters
    I have read all the posts in this discussion and I am quite amazed. I had a Rinnai tank less providing heat and hot water in my home for 8 years with grea success. Bought a new home with a tank. 5 year rental before I can get rid of it. The day the rental agreement ends (62 DAYS FROM NOW) I will be replacing it with a tank less. Savings whatever they are are great, enviroment benefits excellent I guess, but when I want to fill my beachcomber hot tub, or have a shower after my two girls are done showering, the tank sucks. I want tank less because I want endless supply of hot water and a quiet little box that sits on the wall, takes no space, uses outside air for combustion and is never an issue. Yes I also distribute tank less, Navien as well as Noritz. We have well over 1500 in the market. We have had issues but unfortunately 75 per cent of them are caused by sales reps under sizing and over promising. I have also been called by end users who can not fill their bathroom tubs or fancy showers with their 50 gallon tank and have no room for another. Two tank less and they thank the contractor and myself every time very. Their are many reasons to purchase a tank less as well as not to.The most interesting part of this thread in my opinion is the one that picks on foreign products whoever may make them. Korean cars are winning car of the year awards, Japanese cars seem to have taken over the market maybe it is time for us North Americans to get our head out of the sand and start embracing and producing better products rather than calling them crap as they take over the market. European and Asian countries have paid much higher utility costs for years thus they produce more efficient products as a way to keep their costs down in the long run. When you talk payback don't forget oil, natural gas, propane and electricity are artificially low in price right now and will be going up in the very near future. PS no yelling or screaming is required as these are just "my thoughts"
  3. #33
    Nov 2008
    Chicago, IL
    Quote Originally Posted by jchaters View Post
    Bradford white makes a nice tanked water heater that can fill your beach comber tub. Also can supply enough water for your two daughtersas well as you. A Bradford White's standard 50 gallon water heater only provides 90 gallons of hot water in the first hour. This unit in their 25 gallon model can provide 155 gallons of hot water in the first hour, the 55 gallon unit can supply 200 gallons of hot water in the first hour..
    Here is the Spec sheet on the units.
  4. #34
    Plumber JJplumb's Avatar
    Jul 2009
    British Columbia
    I find you guys very funny with all the back and forth between your opinions from a home owner to a contractor. The contractor has a boiler put is his house and can make adjustments to his systems very easily because he has been to the training seminars and has used the same basic principles of these systems for years and is comfortable with them. The home owner does not have the same resources and relies on a contractor for the advice (with or without research) tank less water heaters are a proven asset from efficiency and life expectancy. both of these installs are better then a hot water tank. The tank less is 3 times more expensive then the hot water tank but also last 3 times longer then the tanks. Keep in mind that they are 3 times more expensive then hot water tanks based on todays prices, we all know that prices only go up!!!!!! hot water tanks also lose their energy factor as they get older do to insulation breaking down and sediment build up. Tank less water heaters don't have problems with either of these, yes you will have to de scale them every so often depending on how hard your water is. Tank less will be the only thing that is logical for domestic hot water in the near future and if you are not a contractor that is a part of this then you will be left in back of the crowd because majority of home owners will want to get rid of the bulky systems for something is more efficient then a boiler. Navien at 98% efficient is better then any boiler has better warranty and is half the price with the same life expectantcy.
  5. #35
    Nov 2008
    Chicago, IL
    Navien is the worst tankless unit out on the market. It has the highest consumer complaints out there on its performance and reliability. The performance issue is the huge temperature fluctuations it has. They needed to have that buffer tank that they promote so much to help stabilize the fluctuations, but it does not help that much.
    If you really want a good quality Tankless unit I would go with a Noritz or a Takagi unit. I myself like the Noritz for their duel flame burner, it has the most stable temperature output of all the tankless units. Also do not be fooled by the claims of energy savings. Tankless systems are more a luxury item if properly sized and installed, as it will provide endless amounts of hot water. Many that went tankless have stated that they take longer showers now, which eats into the so called energy savings.
  6. #36
    DIY Member ChuckS's Avatar
    Mar 2009
    Aurora, CO
    Quote Originally Posted by SewerRatz View Post
    I would like to throw the unit I have into the mix. We have the Paloma 7.4 and so far it's solid. It also has a duel flame burner, very stable temp output and did cut our energy bills way down.
    http://www.tanklesswaterheaters.com/waiwelaph28ri.html
    I agree my wife and daughter take longer showers but that doesn't negate not heating water through the day and overnight. Not to mention if you go away for the weekend etc... Will it pay for itself is another question all together since ours was $2600 installed but I will say we're very happy with it and I don't miss running out of hot water in the mornings (I am the last in the shower).
  7. #37
    Default Thoughts
    At one time the Wright Flier was a “Fad”, Henry Ford was wasting his time with motor cars and copper pipe was for amateurs who could not cut and thread Galvanized. Everything happens in stages and the first stages are more expensive…at first. Remember the first flat screen TV’s?
    The Consumer report piece is so obviously a hit piece it’s not funny. One day, I’ll take the time to go through it and blow it up, but not today.
    As for Navien, it’s an ok product but plagued by temperature swings at low temp rises. It makes a better boiler than a water heater IMHO. Rinnai is my favorite with Noritz a close second. You might think you are saving $200 in vent with PVC but the unit cost $200-$300 more than a comparable Rinnai and then you have to cut/prime/glue the ugly PVC. Unlike the low profile, single concentric, push-joint Rinnai vent. So what have you gained? Plus the Rinnai gives more hot water and so does Noritz.
    The Navien is 90+ Really? If I have a car that gets 50mpg and a car that gets 38mpg in the driveway, and they are both “OFF” which ones is getting better mileage? We are talking about equipment that only runs for a fraction of the day anyway. I would think actual energy difference is negligible.
    That said, the there is only one product with a nationwide network of trained Authorized Service Providers, a 24/7/365 tech support (in the USA, Not India) and a highly trained Rep network. That’s Rinnai. Nothings perfect, but some things are better than others.
  8. #38
    Jan 2009
    Quote Originally Posted by Scott D. Plumber View Post
    Yeah, I too get a bit of a laugh out of the "98% thermal efficiency" numbers for Naviens, in much the same way that I do with the overzealous mod-con boiler advocates.
    An on-demand hot -water heater almost BY DEFINITION short-cycles on most of it's burns. Anything less than 5 gallons would be an efficiency-robbing short-cycle for tankless, condensing or otherwise, and even though the bulk of the water use is indeed bathing/shower draws greater than 5 gallons, the numbers of short-cycles, the fixed-losses per burn (flue purges & ignition sequences) add up- they aren't anything LIKE 98% efficient, or even 90% in real-world situations, no matter what their EF number is. (An EF test takes 10+ gallons at every draw, enough to signficantly inflate the performance of a condensing tankless.)
    What determines the real as-used efficiency is how well the unit manages the fixed losses on short-draws of 2 gallons or less, not whether it's condensing/non-condensing. Depending on real world use patterns and the fraction of large/small volume draws, a non-condensing tankless will run anywhere from 75-80% efficiency, whereas a condensing unit might run 75-85%, no more.
    Used as a condensing space-heating boiler a condensing tankless can indeed hit 90%+, but only if the return water entering the tankless is below 110F. In order to hit 98% the return water would have to be under 70F. While not-too-likely in a heating system, 98% efficiency possible for high volume hot-water draws, since the water from street is typically well below 70F. But the average efficiency as a hot-water heater will always be considerably lower than it's steady-state thermal efficiency.
    Tankless HW heaters see a huge number of ignition & flue-purge cycles, robbing efficiency as well as wearing out some of the sub-systems. Even a small well-insulated buffer tank can cut the number cycles by more than half and increase the overall efficiency (while getting rid of the "cold-water sandwich" issue) for the efficiency cost of a small standby loss (less than 1%). From a fuel-saving point of view it's not always cost-effective for just water-heating, but in a combi space-heating/DHW system it can be. (Systems using a reverse-indirect like a ThermoMax or ErgoMax as a heating system buffer while acting as a DHW heat exchanger tends to work well for homes with low/moderate design-day heat loads of 25-75KBTU/hour. But if it's an already high mass low temp radiant-slab heating system where lower than 110F temp heating water is typical the reverse-indirect-as-buffer approach is less than ideal.)
    The best selling point for a condensing tankless is when it can use a cheap PVC vent stack instead of stainless/Z-vent for the standard-efficiency model. In installations with long vent runs the installed cost of a condensing tankless + PVC vent sometimes works out to about the same or less than a standard-efficiency unit + Z-vent. In those cases taking the (very modest) efficiency savings offered by the condensing unit seems fair.
  9. #39
    Thumbs up Adaboy
    Love the way "NHmaster" layed into the whole environmental solar, windfarm, hybrid, et al & etc. things and ALL the other useless crap good money is being wasted on - to control what? - carbon emissions! To save a polar bear? Crapola!
    Don't buy it! If we continue to allow the powers-that-be to regulate US (and I mean all the USA) for carbon emissions, we grant them the power to legislate US all out of existence. We're all made of carbon and exhale it all day long. If it were not for us, the trees would all die and we wouldn't even have a "geen" planet to worry about.
    I WAS considering a tankless WH, but it sure don't make $ense to me. Maybe in 10-15 years when I need a WH again, I'll look into it again. That is, if we haven't destroyed the plannet and I am still here TO look into. Don't get me wrong, I am not damming the innovative spirit. I just prefer to spend MY money on something that has proven its self, rather that gamble on something that may not be better and may be less reliable.
    Maybe 10 or 15 years from now, will see that Hybrids and windfarms were the answer. However, I suspect they will go away quietly and we'll not hear from them for much longer.
    Nice to chat with you guys!
  10. #40
    Jan 2009
    Quote Originally Posted by Bring on the heat View Post
    Yeah, and maybe oil will go back to $6/barrel before it hits $120/barrel again (and electricity is going to be too cheap to meter any day now, eh?) ;-)
    With or without carbon taxes, unless the worldwide recession becomes permanent, energy prices will be rising before your recently installed tank HW heater craps out- count on it. North of $4/gallon people using the ubiquitous F150 as their commuter car are going to be looking at hybrids, high-efficiency diesels, compressed natural-gas vehicles, ANYTHING to keep from forking over their paycheck at the pump.
    A decade from now any purchased-efficiency will be more cost effective than it is now no matter how fast we drill, even if all carbon-taxes get repealed. The developing world won't stop developing just so's we can have cheap energy. By 2040 China alone will add another USA's worth of energy consumption. It's been great while it lasted, but you can kiss cheap oil goodbye even in the intermediate term. In the short term coal-seam natural gas drilling over the past decade is starting to pay off for the US though- enjoy the prices while they last. (If Boone Pickens gets his way, cheap natural gas will be history too.)
    What makes you "...suspect they will go away quietly and we'll not hear from them for much longer", anyway? Wishful thinking isn't a very good analysis of energy markets, and the effect of carbon taxes is still quite small compared to the larger market forces.
    But whether & where a tankless makes sense depends on more than just the installation cost or the price of energy though.
    F'rinstance...
    For moderate flow, low volume (and particularly) intermittent users even a cheap low-efficiency pilotless ignition like the Bosch 1600H can make sense. (The basic unit under the cover is now a well-evolved better working variant on the E.L.M. Aquastar from 20+ years ago, many of which are still in use with 15+ years of USA-family type loads on them. The modulation feedback is better, and the ignition system changed, but the heat exchangers & burners are nearly identical.) It's efficiency is only a few percent lower than the whole-house forced draft burners, but higher than the raw combustion efficiency (let alone EF test numbers) of a atmospheric-drafted tank. But it's still low enough that it can be vented into pretty much the same chimney as you would a tank- no need for special vent-pipe materials, and since it's a water-flow-powered magneto type ignition you don't even need to run electrical power to it.
    All of this adds up to a very CHEAP installation as a tank-replacement- you may have to run fatter gas line to it, but beyond that it's about the same, and you gain the benefit of no rust-out leakage (I suppose it could happen in high acidity water), and zero standby loss, and somewhat higher combustion efficiency. I'd rather have one o' them in a weekend condo or vacation cabin than a tank- ANY tank. The downside is somewhat limited flow- in a New England winter you can't run both the dishwasher & laundry while someone is taking a shower and not hear about it. (Output is only ~100KBTU/hr- plenty for a shower even with 40F inlet water, but don't push your luck!)
    An atmospheric drafted tank with a standing pilot is going to run over 75 therms/year in standby losses. The cheapo Bosch loses less than 10 (and then only if used regularly- in long term standby the standy loss is truly zero.) And when in use, well over 70% of the energy ends up in the hot water, compared to ~60-65% for a pretty good tank, if (and only if) there's 60gallons/day running through it. It doesn't take high math to figure out how long it has to last to have paid for itself in fuel-savings alone.
    Then when you figure that you can have 5 or even 10 people in succession taking showers without running out of hot water... There are plenty of situations where they make sense, independently of globule-warming carbon-crap or nickel-squeezin' on fuel. Zero recovery time is nice!
    I've recommended this very unit to several people for these very reasons, with the same caveats to boot. None of them have tracked me down to complain... ( ...yet. :-) )
    Tankless water heaters aren't new (they're about ~100 years old), just new(er) to the US market. In Europe they became the standard primarily for space-savings. For decades many had to be lit by hand and didn't automatically modulate flame to flow, but modulating versions with mechanical feedback have been around for at least 30 years. It's the 80%+ efficiency high-output versions with all of the electronic controls that try to serve multiple simultaneous & significant flows that are (relatively) new, but even those now have a decade of track record behind them with few nightmare scenarios.
    I'm not say they're for everybody, but I've yet to meet anyone who switched over from a tank to a tankless and regretted it later.
    But me, I'm still for using bigger-burner tankless heaters as heating system boilers, getting the hot water from an indirect-fired tank that also acts as the heating system's buffer tank. Most components of the tankless will last longer with far fewer ignition & burn cycles per day/year/decade (you may not get a full 25 years out of the heat-exchanger though), and with very low mass it's standby & cycling losses are far lower than cast-iron boilers. Properly designed & set up, you'll get significant modulation efficiency benefits out of them too, further reducing cycling losses. Again, not for everyone (but not a terrible option for many.) But just retrofitting an indirect-as-buffer-tank onto an existing hydronic boiler would usually be a cheaper & more efficient option than adding a tankless (or tank) hot water heater.
  11. #41
    Quote Originally Posted by JM Plumbing & Heating View Post
    To who ever commented about the Navien tankless water heater system.
    It is all true. Best system we have worked with. Not only do you get stainless steel heat exchangers but Dual heat exchangers with condensing technology.
    The system is 16-20% more efficient than any other regular tankless in the industry.
    Visit us online and Educate yourself-
    WWW.TANKLESSDEALS.COM
    Get your Navien Tankless from us Today!
    You will not regret it at any moment. Look over our gallery for real installation pictures.
    JM, a few thoughts to ponder:
    How many Rinnai's do you install per year? Does not the Rinnai have better water temperature control and higher flow rates? Doesn't it cost a couple hundred bucks less and have better tech support?
    For efficeincy, if you have a car that gets 30mpg and one that gets 35mpg, and they are both in the driveway "OFF" which one is getting better milage?
    Now I get the PVC vent thing, however if the venting is up and out the Rinnai is still less expensive with an easy push joint vent kit and a much better hot water source. These things only run for minutes a day, the rest of the time they are off. I think 90+ is over rated for tankless. Seems to me that tgemperature control and flowrate matter more.
  12. #42
    Jan 2009
    80+ is (quite literally) overrated for most tankless in most installations due to the particulars of the EF test: 10.2 gallon minimum draws are nothing like real-world use, and the short-cycle losses for sub-2 gallon draws erodes efficiency dramatically. In real-world draw profiles 0.82EF type tankless units hit in the mid-70s, condensing versions scoring 0.90+ EF numbers run in the high-70s/low 80s. The higher thermal efficiency isn't worth (much) extra for. (Indeed, you'd get better return in fuel savings on drainwater heat recovery on the main shower for the price-delta on the high/mid efficiency units themselves, vent costs not included.)
    Steady-state thermal efficiency is a theoretical upper limit, but not a good measure of the real-world performance. Those with tight controls over flue purge cycles losses will do better than those that don't. Those with small header tanks to mitigate cold water sandwich issues that also inhibit fire when the header is above a minimum temp will also suffer fewer cycles, and thus lower purge-losses from multiple low-volume draws, etc. Steady state thermal efficiency or raw combustion-efficiency numbers are only relevant for very large or continuous-draw duty (pool heating, anyone?), not domestic hot water for typical household use. In space heating, commercial laundry/car-wash, health-club showers, or home solar-backup you might beat 90% with a condensing tankless, but not very often (if ever) in straight-ahead DHW apps.
    BTW: A a question for any of you who have taken (or will take) the tech courses from various tankless vendors: Is there a modulation level where they typically peak out on raw combustion/thermal efficiency? Do any vendors share any of that data?
    Condensing versions likely peak at lower fire in 25-35% of full-fire range (like most mod-con boilers), but I suspect the single heat exchanger types may do better at the high range (like copper-tube boilers), and may be under 80% for raw combustion efficiency at the low end of the modulation range, but 85%+ in the mid/high range. I could as-easily believe the designs have been tweaked to provide peak efficiency at some other burn level, but haven't been able to find test data (which I'm sure is quite proprietary when tested by the manufacturers). Can anybody either confirm/disabuse me of those guesstimates?
  13. #43
    Nov 2008
    Chicago, IL
    In another thread I posted a comparison between Noritz and Rinnai, its only fair I post the Noritz Condensing unit (PVC venting) against the Navien. http://www.noritz.com/u/noritz_841mc...ien_cr240a.pdf
  14. #44
    i have had nothing but problems with navien /// not the water heater but with the warranty /////david mills is a jerkoff and is the man incharge of warranty dont do any warranty work because you wont be reinbursed for your expences let them send there man from the factory so so he can fix it ////im not sure wich brand im going to but im sure i wont sell any more navien
  15. #45
    Feb 2005
    Talking sounds litk you are not happy with navien
    Quote Originally Posted by Dovels INC. View Post
    I guess that you sell and install this brand??
    sounds like youi have been hung out to dry
    by their warranty department...
    god created all men,
  1. First Post: Navien tankless water heater question
    By BillM18641 in forum Tankless Water Heater Forum
    Last Post: 11-06-2011, 01:30 PM
  2. Smell of Gas - Navien Tankless Heater
    By cawhitehead in forum Tankless Water Heater Forum
    Last Post: 08-21-2011, 05:43 PM
  3. navien tankless water heater
    By imktc1 in forum Tankless Water Heater Forum
    Last Post: 01-10-2011, 04:10 PM
  4. Navien Tankless Water Heater---Well Pump Setting
    By JTCA in forum Tankless Water Heater Forum
    Last Post: 11-07-2010, 02:53 PM
  5. Navien Tankless and Hot Water Circulator
    By mn4az in forum Tankless Water Heater Forum
    Last Post: 01-29-2010, 10:42 AM
