The plumbing codes do not address boilers but the National Mechanical code does. However, it does not say you need a dump zone. However, the rule is that you do what the manufacturers instructions say at all times.
I recently posted about a indoor wood boiler. I was wondering if there is anything in the IPC/IRC/IMC that requires a heat dump zone for boiers in the event of a power outage? When we had our Greenwood 100 installed we requested that it be "protected" by a dump zone for power outages to minimize the chance for boil overs. It seemed like a reasonable request but we did not get that. I expect a TP valve is required at the least. Looking for some recourse on a job gone bad and the installer will not do the work to make it right. Any thoughts?
http://www.inspectpa.com/forum/forum.php
My answers are based mostly on the ICC codes. Advice given is my personal opinion and every person performing work should acquire a permit from his/her jurisdiction and get the work inspected. My opinions are not directions to follow for DIYs or professionals
