Results 1 to 7 of 7
Thread: turning off a lamp
    DIY Senior Member v1rtu0s1ty's Avatar
    Sep 2006
    Chicago IL
    Default turning off a lamp
    Hi folks,
    I'm going to build a mini greenhouse for a plant. Inside this mini greenhouse is a 100 or 150 watt lamp. I'm looking for a cheap solution that can turn OFF this lamp when temperature inside greenhouse reaches 40F. It can also turn the lamp to ON when temp inside greenhouse goes down to 30F. I'm not really good in electrical so I don't know what to look for. Right now, I'm thinking thermostat but that's it.
    Are there products like this?
    Quote Originally Posted by v1rtu0s1ty View Post
    Hi folks,
    First buy a thermometer and install it inside your house near a window that faces the greenhouse.
    Next install this product and use it whenever you see the temperature at the limits you want:
    http://www.inspectpa.com/forum/forum.php
    My answers are based mostly on the ICC codes. Advice given is my personal opinion and every person performing work should acquire a permit from his/her jurisdiction and get the work inspected. My opinions are not directions to follow for DIYs or professionals
    Seriously, contact this company and just make sure that the products are UL listed.
    http://www.littlegreenhouse.com/acce...controls.shtml
    Sep 2006
    Chicago IL
    Quote Originally Posted by jar546 View Post
    Awesome. I will contact them tomorrow. Thanks for the link.
    So looking at the link, what I really need is the heating outlet. That is an awesome product!
    Thanks again!
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    The thermostat contacts have to be able to handle a tungsten load. If you can't find one, you need to have the tstat control a relay that can handle a tungsten load.
    Plumber jimbo's Avatar
    Quote Originally Posted by Thatguy View Post
    I will go out on a limb and say that any product which is designed to have a regular AC plug plugged in to it will be adequate for a 100 watt flood bulb. But of course, I am sure the manufacturer can provide a detailed spec sheet to be sure.
    Aug 2008
    MD
    And I will be busy sawing off the limb you are on!
    You're probably right. This is not some huge incandescent or motor load.
