Results 1 to 4 of 4
Thread: Chemical odor from central heating's chimney
    Default Chemical odor from central heating's chimney
    Hi all,
    I have an outdoor natural gas central heating unit (which also has a built-in AC). On the side of this large box-like unit is a small vent that outputs hot air/gasses. The odor of these gasses has a VERY strong "chemically" smell. Is this normal, or might there be excessive unburnt natural gas mixing with the normal heater vent exhaust? And can this be dangerous?
    Thank you!
    -Bill
    Default Answer to furnace vent odor...
    To save anyone who may read this thread in the future: the smell from the vent was caused by poisonous gasses due to a cracked combustion chamber in the gas furnace.
    There are only two solutions to this problem (that is, if you lived through the carbon monoxide poisoning that this issue causes): replace the combustion chamber (>$1500), or get a new central heating unit (>$4200).
    PS: I'm really somewhat surprised that this HVAC forum didn't know the answer to this critical life and death problem...
    -Bill
    Thanks for posting that.
    BTW, this is first and foremost a plumbing forum. HVAC questions that are are more serious than just replacing the thermostat are often given the standard answer, "Call your HVAC professional."
    PS: Didn't your CO detector go off, alerting you to a hazardous situation?
    DIY Senior Member burleymike's Avatar
    Nov 2008
    Idaho
    If that smell is coming out of the exhaust what would that have to do with a cracked exchanger? If that smell is coming out of the supply ducts then it makes sense.
