Yersmay using the flux brush to "smooth" out the solder joint while it is hot is the same as taking a rag and wiping the joint. As I posted from
www.copper.org website it says sudden shock cooling and or wiping the joint is bad. Using a flux brush is considered shock cooling since, and you can be adding flux to the joint pushing out any molten solder. I just talked to one of the union instructors the other night. There is a ASTM standard for soldering pipes. ASTM B 828 and there is a test for this standard. In the test it says the joint is fail if to much solder was used, to much heat, and if the joint was wiped or shock cooled. So basically a proper solder joint is just the right amount of flux, heat and solder to fill the joint. After the solder joint is cooled they cut the joint in half long ways and peal apart the pipe from the fitting and inspected for any defects.
speedbump Heh, I made that mistake with a pair of gloves holding a pipe that was being soldered. All I can say is ouch. The union instructor also told me many plumbers come from the school of my dad, sponsor, or whom ever taught them did it this way. But it never makes it the right or proper way. I will admit when I first started into plumbing I learned to wipe away the tits and the joint while it was hot. But when I took the state test the state inspectors told me different.
