If the well is a low producer, then a storage tank, booster pump, and pressure tank will be needed. If the well is a good producer, then you need to accomplish everything with the well pump, and a booster pump is not needed.
If the storage tank is needed, then a regular jet pump, pressure tank, and pressure switch would be more dependable and less expensive.
However, if you like selling things that cost a lot and don't last very long, then a variable speed pump is what you need.
