Thread: Valve Does Not Open
    DIY Junior Member
    Dec 2008
    Florida
    Angry Valve Does Not Open
    My neighbor has a six zone Hunter sprinkler system and the 1 inch valves on zones 1 & 2 do not open. The solenoids are getting power and I have disassembled the valves, cleaned them, and reassembled them, and still no luck. Even when I unscrew the solenoids, they still do not open.
    I'm "dazed and confused"................
    Eureka!!!! When cleaning the valve, I didn't notice another vent/orifice directly under the solenoid plunger. It didn't look like there was an opening because it had sand in it!!! I found a thin wire and shoved it through the opening, and the sand came out at the tip of the wire. I reassembled the valve and it works like a charm!!
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    If the solenoids don't actuate, they aren't getting enough current. Suspect poor wiring.
    Look especially closely at the ground wire. The usual way to connect a series of valves to ground is to daisy chain them. There could be a loose connection in the links.
