Usually when this happens, it is because your pressure switch is bouncing the pump back on, immediately after the pump turns off. A check valve between the pressure switch and pressure tank may be the problem. Could also be a bad tank or a bad pressure switch. Watch the points on the pressure switch as the pump shuts off. If they pop open and then close immediately, it will cause the kind of problem you are having.
