Originally Posted by
Gary Slusser
If you didn't pull out the clear plastic, you didn't do anything but spin the meter dial. That doesn't change any settings. The numbers are the settings and you shouldn't change them. The regeneration resets the meter.
You didn't fool with the pin settings right?
Did you clean the injector etc. etc.?
Use it this way for 2-3 days and see how the water is. And get raw water tests for hardness and iron.
If you have a digital camera, a clear close up picture of the timer and then the left side of the control valve from like a 45* angle down at it would help.
