Results 1 to 5 of 5
Thread: Question on crimping tools
    Default Question on crimping tools
    Hi,
    I need to make a connection between polybutylene pipe and pex pipe. I have found a pex to poly converter to do this. What I am unsure about is the crimping tool. Do I need two crimping tools (one for the poly connection and one for the pex connection) or can a pex crimping tool also be used on poly pipe? Alternatively, is there some kind of universal crimping tool that can handle both types of pipe? Any recommendation of specific crimping tools that people have used successfully would also be appreciated.
    Neil
    Default tool
    You should have also gotten a special crimp ring for the PB so it can be used with the regular crimping tool.
    It seems silly to invest in any crimping tool for just one connection. A Qest compression coupler will do the trick.
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    Sharkbite it.
    Dec 2007
    Quote Originally Posted by kingsotall View Post
    Sharkbite it.
    I agree!
