Results 1 to 11 of 11
Thread: cleaning plumbers putty fingerprints of Stainless sink?
    DIY Senior Member bbillcee's Avatar
    Feb 2007
    NY
    Default cleaning plumbers putty fingerprints of Stainless sink?
    any suggestions?
    Plumber Cass's Avatar
    WoW...try soap and water...
    Feb 2007
    NY
    Quote Originally Posted by Cass View Post
    LOL i did they still show up ....i thought maybe there was a trick
    Plumber Sandpiper Plumbing's Avatar
    May 2008
    Northern by birth, Southern by choice
    I use GlassPlus and a soft towel, let it soak for a few minutes and it usually wipes right out with a little elbow grease.
    Feb 2007
    NY
    LOL sorry for the stupid question!
    Try a damp rag with some dish soap placed directly on the rag and work it in...
    Are you sure it is plumbers putty and not caulk...normaly plumbers putty comes right off...
    Aug 2008
    Stainless Steel Magic┐
    DIY Senior Member Mike Swearingen's Avatar
    Jan 2005
    On Albemarle Sound In Northeastern NC
    Oops! solvent and cleaner will dissolve most anything sticky, including chewing gun, adhesives, etc.
    Mike
    SS can be somewhat porous, and most plumber's putty has some oil in it. Oil stains need a solvent to remove if embedded.
    Default fingerprints
    If his are on the sink then anyone else who touches it will also leave marks. Bartender's Friend cleaner is usually what is used.
