I have seen that before. Pressure tanks can take a lot of pressure but, not much vacuum. Usually the check valve in the well is bad, big hole in the drop pipe, or the pump falls off the pipe. The water going back down pulls a vacuum on the tank unless some air can get in from a tap or a leak. Also can happen if you pump water down hill, and you have a break in that line.
