Well, no. In fact, if you put some plastic on the bottom of the studwall on the concrete, you don't need it there. You could use some seam-seal like they put on top of the concrete wall for the rim joist. PT wood is absolutely horrible in that is twists, shrinks, and bows when it dries out. Not at all the thing you want behind a shower wall where tile are involved. A properly done shower should never introduce moisture into the framing, so if you can keep it from being in contact with a potential wet slab, you should be fine. If you have a wet slab, you've got other problems...
I'd check out the people at www.johnbridge.com for shower construction details.
