Originally Posted by
1. I would NEVER try to snake the line through the toilet opening, unless it was the absolutely only way to do it.
2. If his snake was smaller than yours, which appears to have been too small to do an adequate job, then he made an opening in the stoppage, he did not clear it.
3. A proper sized and located cleanout is the correct way to do a proper drain cleaning.
4. The drain line is at its shallowest point, and easiest to locate, where it leaves the house, so that is usually the point where cleanouts are installed, if they are going to be located outdoors..
