Results 1 to 11 of 11
Thread: Kitchen Counter Sink Hole Standards
    DIY Senior Member jerome8283's Avatar
    Oct 2006
    New York
    Default Kitchen Counter Sink Hole Standards
    Is there is standard hole size and distance between holes for kitchen 3 hole configurations?
    Geologist sjsmithjr's Avatar
    Dec 2005
    Knoxville, Tennessee
    Most kitchen faucets are 8-inch outside center to center. I.e., three holes, 4-inch on center.
    Are you drilling your own countertops or just shopping for a faucet?
    -Sam Smith
    Licensed Professional Geologist - AL, TN, KY
    Oct 2006
    New York
    Quote Originally Posted by sjsmithjr View Post
    We'll have granite installed Friday and the installer will drill the holes onsite. I purchased a 3 hole faucet config and was just wondering about the holes to be drilled. Actually I will have one more hole for the filtered water faucet. By what I've seen the 3 holes for the faucet (faucet, soap and lever handle) are drilled 1 3/8" each, 4-inch on center and the filtered water faucet can be placed where I want it?
    Dec 2005
    1-3/8" is the hole size. I'm no countertop installer or plumber, but I would assume that there is a setback from the sink lip as well. I can't tell you that one off the top of my head, but one of the regulars or pros should be along with an answer before the actual installation.
    Just a heads up, you may also receive well intentioned advice regarding radon and natural stone countertops. If this is not a discussion you wish to engage in, you may want to simply say so to avoid thread drift.
    -Sam Smith
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    As sjsmithjr said, kitchen sinks are either 8" configs, or single hole configs. You seem to have alot of going on there, so the 8" would probably be best; it will give you the most flexibility in the future, as well as give you good spacing between the different fixtures. Basically the faucet you bought is going to determine hole requirements, so just look at the instructions and see what it calls for, then just add another hole with the same spacing for your filtered faucet. If your countertop isntaller knows what they are doing, they should already knows this.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Oct 2006
    New York
    Thanks guys.
    I'm aware of the possible radon issue as well.
    FWIW, I used a one-hole faucet on the back right side, a small filtered water hole directly centered in the back, and a soap dispenser on the other back left side of the D-shaped sink - all of the fixtures are around the back side of the curved section. The faucet is high mount, and it makes it easy to swing is to the side and fill a pot sitting on the counter (rather than in the sink, which might be full of other things!). It's worked out great. Maybe a little unconventional, but by having it on the side, you don't have to reach over the sink to turn on the water so it makes it a little easier for shorter people...
    Oct 2006
    New York
    Yeah, I was thinking about the off to the side mount as well. I guess I've just been so use to the center mount itís hard to change but I certainly understand your decision.
    Default faucet
    You appear to be going old fashioned. Very FEW granite sinks are installed with a "3 hole" faucet these days. The standard is almost always a single hole faucet, usually with a pull-out spout/spray.
    Oct 2006
    New York
    It is a single hole faucet with pull-out spout/spray but requires 2 additional holes for the soap dispenser and lever handle.
    Default holes
    In that case you can put the holes anywhere you want them. The standard 4"-4" spacing is to accomodate faucets the require two or three holes.
