Results 1 to 12 of 12
Thread: Extra part?
    DIY Junior Member
    Dec 2008
    Fallbrook
    Default Extra part?
    Installing a Pegsus tub and shower unit. I have a part that I can"t seem to locate in the diagram. 3/4" male on one end with two O-rings on the other 5/16" apart 1/2" from the end, with two flat 1/2" grooves at the end. Lenght of pipe is2 1 1/2". Model# 566-712 Seris 1000 I think
    Plumber jimbo's Avatar
    Could be part of the tub spout. On the other hand, GB and Peg. from HD......not unusual to find missing parts, or extra parts....... If that piece you have is extra, someone has a box with that part missing!
    DIY Junior Member
    Dec 2008
    Fallbrook
    What is GB and Peg? GB20030113 is a number on a sticker un the valve
    Plumber Cass's Avatar
    Nov 2005
    If the box was open when you bought it the part was removed from the box to repair someones faucet...when purchasing at big box stores never buy opened boxes. This is one of the most common problems...
    Quote Originally Posted by samson33 View Post
    Glacier Bay and Pegasus. The Home Depot brands, made by the Globe Union Industrial Faucet Company of China.
    Quote Originally Posted by Cass View Post
    You do realize that they have the thermal strapping machine in the store, and when a box is returned, they restrap it before putting it back on the shelf.....!
    Nov 2005
    I rarely go to HD and dodn't know they did that...at the Low*s i go to they don't restrap.
    DIY Junior Member
    Dec 2008
    Fallbrook
    Checked the tub spout you mentioned. Now I have another problem. Plastic sleeve inside spout with a set screw on the bottom. Thought spouts just screwed in? Does the plastic need to be removed?
    Nov 2005
    that one is made to slip over copper pipe and the set screw just keeps it from spinning...
    Default spout
    You are describing things in such a way as to confuse us. Pegasus copies a lot of Delta parts, so that first piece could be the spout adapter, but if so you should not have the clamp on spout you refer to in the second posting. We need pictures to see what you are talking about.
    I would check the back room on that one!
    Dec 2007
    When I purchase a strapped box at any big box I open, inventory, and inspect, before going to the register. Unfortunately sometimes while working Saturdays I do have to deal with big box stores and I don't trust either!
