Results 1 to 3 of 3
Thread: Wiring bathroom exhaust fans, GFCI concerns, NEC concerns.
    DIY Junior Member rick15752's Avatar
    May 2010
    California
    Default Wiring bathroom exhaust fans, GFCI concerns, NEC concerns.
    Hi everyone,
    I'm renovating my bathrooms, 2 are second floor and 1 on the first floor. I'm in California. These bathrooms are small, 5 x 11 upstairs and 5 x 7 downstairs, and all have windows. However, building code now states that mechanical exhaust fans must be installed in each bathroom that has a tub or shower, regardless of the presence of windows. All bathrooms have showers. The home was built in 1985 so there is a single circuit that serves all bathroom outlets protected by one GFCI in the master bath. There is a separate circuit for the lights. If I'm interpretting the NEC correctly, 210.11(3) says you cannot run other things from the GFCI protected bathroom circuit. Can someone confirm? I was hoping to do that with the bathroom exhaust fan in one bathroom where I would place a Broan 744SFL on the ceiling in the shower area. The ceiling height is 87". The Broan 744SFL is rated for use above the shower as long as it is protected by a GFCI circuit.
    I don't want to run a new circuit from the panel. An alternative might be tapping into the light circuit to power a second GFCI which would then serve the fan controlled by a switch.
    Any NEC issues with that? A building permit was secured for the renovation work.
    Thanks.
    Rick
    Nov 2009
    VA
    Since it looks like you are feeding two (or maybe 3?) bathrooms on that 20A circuit, then I agree that it looks like you cannot feed the fan off of your GFCI circuit. There is an exception to 210.11 (it is on the next page from where you are looking if you are using NEC 2008) that allows you to run the other bathroom fixtures (lights, fan, etc.) off of the 20A circuit IF you are only feeding just that one bathroom with that circuit.
    Could you move the fan so that it isn't directly above the shower and avoid the GFCI? Another option would be to take the lighting circuit, run to a box with a GFCI (could be a dead-front style (no outlets)) and then connect to your fan.
    If you haven't bought/installed the fan yet, you should also look at the Panaasonic fans. They are quiet, well built, and move a good about of air. I highly recommend them.
    Any other rooms in your house besides the bathrooms? Then you are in luck! Find an easy to access outlet in one of those other rooms that is as close as possible to the bathroom, is easy to access, and has a wire count low enough to allow you to tap into it. Replace this outlet with a GFI and feed your bath fan from here.
    There is no reason the GFI must be in the bathroom with the fan/light.
    -rick
  1. Wiring Bathroom/GFCI Circuit
    By 41Fever in forum Electrical Forum discussion & Blog
    Last Post: 01-19-2010, 05:08 AM
  2. Bathroom Exhaust Fans - keeping things out
    By rschmitty in forum Shower & bathtub Forum & Blog
    Last Post: 09-26-2009, 09:52 PM
  3. AS Cadet PA concerns
    By CarlH in forum Toilet Forum discussions
    Last Post: 12-16-2008, 10:11 AM
  4. Venting multiple bathroom exhaust fans
    By Basement_Lurker in forum HVAC Heating & Cooling
    Last Post: 04-06-2008, 02:36 PM
  5. Ducting exhaust fans in bathroom remodel
    By LLH in forum Remodel Forum & Blog
    Last Post: 05-04-2006, 07:41 PM
