Results 1 to 5 of 5
Thread: Toilet waste line
    DIY Member K2's Avatar
    Jul 2008
    Delridge Valley
    Default Toilet waste line
    Hopefully a simple question, I didn't see anything directly related to it on the site:
    Can the waste line of a toilet run perpendicular to the toilet?
    I.e. the Toilet faces North/South and the waste line to the main stack would be run East/West.
    I guess in my mind it seems like this could cause flow problems but as long as the right grade is applied it should be o.k., no?
    Assuming other aspects of running the line are done properly, this will be no problem.
    Default toilet
    You can run it in any direction you want, even straight down, except upwards.
    Jul 2008
    Delridge Valley
    Thanks! Is there a limit on how far it drops before the Elbow that runs to the main stack? My joists are 6x6's.
    Even below 2x12's would be fine.
