Results 1 to 5 of 5
Thread: Intermittent ignition on W-M boiler, Beckett AF oil burner
    Default Intermittent ignition on W-M boiler, Beckett AF oil burner
    We had our unit's annual service several weeks ago. This included the full complement - cleaning, new filter, nozzle, igniter gap check, etc. Since the heating season has started there are many times when the unit attempts to light and then times out. If I hit the reset button it will sometimes light, but if not, while attempting to light, I can get it running by inserting a propane torch into the inspection port.
    Yesterday I removed the electrode assembly after some difficulty as the splined nut that holds it tight to the escutchion plate seemed misthreaded. I cleaned the electrode insulators (were covered with soot and "tar"), adjusted the gap which was pretty close to specs, and replaced the connector tube with a new one. The rest of the day yesterday the unit lit promptly, and I was cautiously patting myself on the the back.
    Of course, this morning it failed to light until I hit the reset button and it started up fine.
    One thing i did notice yesterday is that the igniter tips are fairly blunt. Are they supposed to be sharp points?
    I'd appreciate any thoughts before calling the company for a service call. Thanks loads!
    Master Plumber nhmaster's Avatar
    Jul 2008
    S. Maine
    Think I'll need the optional chin strap for this one boys.
    Call a HEATING TECHNICIAN before you burn you house down.
    Dec 2007
    Quote Originally Posted by Baltimore Lou View Post
    Call them now! Sheesh!
    Smile Service tech just left...
    after replacing the transformer. System is now working fine. Your advice, while blunt, was appreciated. Thanks!
    Dec 2007
    Thank you for calling them.
    You were treading on dangerous ground.
