Results 1 to 11 of 11
Thread: Name these Totos
Hybrid View
    Default Name these Totos
    Please help me identify the model of these toilets. These are pics taken by Craigslist seller.
    Is there enough room to feed water supply line behind the toilet? If facing the toilet the supply is plumbed on the left, these toilets look like the supply is on the right, under tank. I have a 12" rough in. The seller wants $225 for both.
    thank you
    Rob
    The C874 is a Carlyle, MS874114S
    The C884 is a Carolina MS887114
    Looking at the front, the water supply would be on the left, at least 7" to the left of center.
    From the pictures I can't tell if you would be getting the bolt covers on the side of the bowl or the required Unifit adapter with the toilets.
    The C884 is a Carolina MS884114
    Dang your good!
    Terry,
    I think I scored big time for these two toilets ($250 for both). I picked them up last night. One of them needs basically all the guts for the inside and the Unifit adapters came with them but are used. I might just buy new ones. Do I buy the Korky with flapper parts or the "Fits Toto" valve and separate flapper?
    Thanks again Terry,
    Rob
    Well, I don't know it that was such a great deal for two used toilets, but you will need a Toto flush valve and flapper, not generics. I don't know if Lavelle ( Korky ) makes a "will fit" but if you get an iffy flapper, you will have iffy performance.
    Jimbo...given the cost for new ones it seemed like a good buy, these were used for a year then stored in garage for several, oh well, there mine now. Korky does make one but their website doesn't have a shopping side to it. I went to HD, ACE, and LOWES but they don't carry the Toto version.
