Results 1 to 8 of 8
Thread: EverPure Water Filtration
    DIY Senior Member jerome8283's Avatar
    Oct 2006
    New York
    Default EverPure Water Filtration
    Does any have experience with under sink mount water filtration cartridges? I have 2 cartridges made by EverPure (Voc#1 & Voc#2). I need to replace them and would like to know if they need to replaced with Everpure specific cartridges or can I reaplace them with some other compatible manufacture? Also can they be purchased at the big box stores?
    I believe they are proprietary. I've never heard of then sold through big box stores but they may be.
    If they are the ones I am thinking of , they are NOT generic, and they ARE about a C-note each.
    Oct 2006
    New York
    I found them online...
    http://www.superwater.com/voc12.html
    For the price of one of those cartridges you can buy a whole new filter including off the shelf industry standard cartridges and a long reach swivel faucet.
    Oct 2006
    New York
    Yes, I notice that this morning at Lowes. I will definately switch to the newer systems. Thanks
    Oct 2006
    New York
    ok I picked up the Whirlpool WHED20 under sink mount system to replace the old system I have now. I need to return because I opened the package and the filters were missing.
    Anyway, my old system has a saddle valve clamp with a small valve handle connected to my cold water supply were the blue 1/4" tubing is connected going to the filter. The new system has 3/8" tubing. Is there a transition connector available?
    Oct 2006
    New York
    I picked up a Quick Connect. All is well now. Thanks
