Page 4 of 6 FirstFirst 123456 LastLast
Results 46 to 60 of 80
Thread: DIY Electrical
  1. #46
    Jun 2007
    NY State, USA
    I think it shows up in the first post of the page, which changes as more posts are added.
    Yup, I've noticed that too. Sucks because FF Ad Block Plus does not recognize it as an ad.
  2. #47
    Aug 2008
    I vote for having the ad appear in every one of Frenchie's post.
  3. #48
    DIY Junior Member jamiedolan's Avatar
    Nov 2008
    Wisconsin
    Quote Originally Posted by jar546 View Post
    Professional Work:
    DIY Work:
    Is the NM standard colors? White NM 14 awg and the yellow 12 awg?
    If so, the 20A outlet violates 210.21(B)1
    Jamie
  4. #49
    Jun 2007
    North Carolina
    Quote Originally Posted by jamiedolan View Post
    Jamie
    That is real close but the section would be Table 210.21(B)(3)
  5. #50
    Dec 2006
    Quote Originally Posted by kingsotall View Post
    Do I get a cut of the action?
    Master Plumber Mark:
    do not hit your thumb...
    __________________
  6. #51
    DIY Junior Member apparentgenius's Avatar
    May 2008
    Oregon
    Here is a good example.
    If you look at the photo of the Professional job that looks great there are no safety hazards but there are still 3 code violations that caused the job to fail. They are small and not really safety related but still code violations.
    Can any of you DIYrs see the 3 code violations in the professional photo?
    Ok,
    I'll open myself up for abuse. I'll go for it looks like the runs are stacked and stapled more than 2 deep, the bend radii look tight and the receptical box looks like it isn't very securely mounted.
    glen
  7. #52
    Nov 2008
    Wisconsin
    Quote Originally Posted by apparentgenius View Post
    Ok,
    glen
    Add not all cables are stapled within 12 inches of panel.
    My addition; 20A outlet being fed with 14 gage NM, No one else seemed to mention this.
    Jamie
  8. #53
    That is because it is on a 15A breaker so it is a moot point.
    http://www.inspectpa.com/forum/forum.php
    My answers are based mostly on the ICC codes. Advice given is my personal opinion and every person performing work should acquire a permit from his/her jurisdiction and get the work inspected. My opinions are not directions to follow for DIYs or professionals
  9. #54
    Electrician Chris75's Avatar
    Aug 2007
    Litchfield, CT
    How do you figure? Its a code violation, Only a single receptacle on an individual branch circuit shall have an amprere rating not less than that of the branch circuit.
  10. #55
    May 2008
    Oregon
    Ok,
    glen
    Well, was I close?
  11. #56
    Quote Originally Posted by Chris75 View Post
    Exactly, NOT LESS.
  12. #57
    Jun 2007
    North Carolina
    Well, was I close?
    I will pay you some attention when it seems no one else will. Close but maybe not close enough.
  13. #58
    May 2008
    Oregon
    ok, then is the third one that the cables need to be stapled within 12" of the panel and not that the recepticle box is half on/half off of the strandboard?
  14. #59
    Aug 2007
    Litchfield, CT
    Exactly, NOT LESS.
    Ha-ha, too bad in the pic its a duplex and NOT a single receptacle, check out art 100 definitions, Also, check out Table 210.21(B)(3). A 20 amp DUPLEX receptacle is a code violation when supplied from a 15 amp circuit, Where a 20 amp SINGLE receptacle can be supplied from a 15 amp individual branch circuit.
  15. #60
    Chris, that table only applies when branch circuit supplies 2 or more receptacles or outlets.
    If you looked inside this panel, like I did, you would see that this receptacle was on a dedicated circuit and supplied no other receptacles.
    Keep reading, it is a good learning experience for both of us.
