Hi all: I'm new to this business. I really liked some of the posts so here I am.
My pump short cycles. I'm trying to find out where the problem is. This is what I know so far
--the well mate tank wm6 seems light and empty, no condensation
--the pumped is submersed. I have have no record of what type it is
--I pumped tank up to 40lbs (doesn't take but three pushes on a bicycle pump), seems like I gain a second between short cycles, then drops to its regular 3 second interval
--if I bleed air out of tank, water comes out through the schrader valve ...though it seems empty for the most part
--pressure gauge on pipe is broken and has water in it
--pressure gauge is in line with the pipe from the water tank, but there's two faucets on either side of it (one on the pipe coming from the well, one on the pipe going to the house)
--there's water on the ground under the tank
I am hoping that the problem is with the tank and not the well. I'm confused as to why water comes out of the schrader valve and still the tank seems empty. Is this enough info to paint a picture as what the short cycling problem might be?
Jason
Jason
