I have a gas fired water heater (American flameguard) that is 4.5 years old and I also have a water softener. After the water was installed for six months, the unit began to rumble loudly when a lot of hot water is used for a shower. I am in the room directly above the water heater and you can hear it thump and rumble 4 or 5 times during a 10 minute shower. The plumber was not much help so I decided to order an anode rod. The plumber put it in and the rod did not look eaten but was encrusted with a quarter inch of white stuff. The noise stopped but then returned after six months or so. So I have been changing the rod every time but I am still not sure what is happening. I recently flushed the tank and nothing came out. I have not tried draining it however, which I will probably do soon. But I am looking for any suggestions people might have.
Another symptom that I see is the upstairs bath faucet expels a burst of gas/air out of the hot water side after its running a few seconds, this problem disappears when the anode rod is changed and the thumping goes away, the first floor kitchen sink and bath do not have the problem, any ideas on this would also be appreciated.
