I would definitely check the wiring in the thermostat. Make sure no wire is touching another and that they are all screwed in tight.
If that doesn't solve the problem, you may want to replace the thermostat. After that, it's time to call an HVAC tech. Depending on what model furnace you have, there could be a plethora of other things to check, such as a bad fan switch, fan limit control, faulty wiring, etc...
