Results 1 to 4 of 4
Thread: Check valve on a closed loop hydronic system?
    Default Check valve on a closed loop hydronic system?
    As mentioned in another thread I am putting together a small closed loop hydronic system . The Taco circ pump I have purchased has a integral check. My system will have about 18" of head.
    Should I remove the check in the pump?
    What are the advantages/disadvantages of removing it?
    Regards,
    Chris
    Leave the check valve...
    Thanks for the reply Jim.
    I am trying to learn here so help me out. Can you expand on why you think it better left in?
    Chris
    Without a checkvalve, when the pump is off, you'll still get circulation because of the difference in height and temperature. So, things could continue to get heat when you don't want it.
