In my basement, which encompasses a 12 x 22 den/activity room (for the kids) and will most likely double as a home theater and guest room, a 11 x 16 office and a 11x16 laundry/storage room. In the main room (den) i'm putting four 2'x4' flourescent troffers (four t-8 bulbs) in a drop ceilling, three in the office and two in the utility room. the key thing is that i'm replacing all the bulbs with "natural light" tubes (6500K, 85 color rendering factor). this provides a lot of light for the kids reading or doing work books, working in the office and the laundry room. for the purposes of the home theater / guest room, i'm putting two sets of recessed cans along the walls, parallel to the line "connecting" the couch and TV. I'll also put a set of recessed lights along that same line to high-light the center line, couch and coffee table. both sets of recessed lights will be on dimmers. the outer lights will be mostly for mood/ambiance/wall-washing and will be lower wattage. the center-line lights will spot light couch, coffee table and midline of the room for reading, and will be turned off to watch tv, so will be higher wattage. we also have a fireplace which i plan to bracket with sconces - mostly for atmosphere.
the flourescents in the office and laundry room are controlled by toggle switches. In the den, with a motion sensor, but on that can accommodate a manual override switch (single pole, or 3-way/4-way run) so i can prevent the sensor from turning the lights on (while watching a movie or when guests are sleeping). the beauty of this sensor is that it lets me use lighted 3-way switches so that when the sensor is overridden, a quick glance at the glowing wall switch will indicate the status.
any particular reason why you're wanting to avoid flourescent fixtures?
