az1324
- Messages
- 21
- Reaction score
- 0
- Points
- 0
I'm replacing a tub with a shower and plumbing the drain. I am removing the reducing tee and using a 2" drain instead of the 1.5". The drain, however is situated directly above a joist and there isn't room to place the p trap in that spot. The joist has already been notched, and I do not wish to notch it any further to avoid completely compromising its integrity.
So can I just elbow over and up from the p trap using 2 90 deg fittings? Just want to confirm that this is ok for proper drainage.
Edit: Ok that's not really helpful as an elbow takes up just as much room vertically as a p-trap. What I'm gonna do is 22 up from the tee and 22 back to horizontal then the p trap will be raised above the joist and be just low enough to make the connection. Sorry for wasting a thread. Delete if desired.
