Results 1 to 8 of 8
Thread: How can I increase the temp of my Mix-it valve.
    Default How can I increase the temp of my Mix-it valve.
    I had a new bathroom built in June. All new construction. I noticed that the hot water in the shower is not as hot as the sink. The contractor installed a new Delta mix-it valve. I turned up the temperature at the water heater as instructed by the plumber but there is no real change. What should I do to get the water temperature to increase.
    Dec 2007
    It would help if we knew which Delta Mixit valve you have...
    Can you post a pic?
    Plumber Winslow's Avatar
    Dec 2005
    Hawaii
    Quote Originally Posted by Gabe View Post
    Behind the handle there is going to be a temp limit/ scaldguard stop. adjust it to allow the handle to turn further to the hot position
    Default valve
    Delta and Mixet are two different companies. Mixet is out of business so I hope you do not have one of those in a new shower.
    Dec 2007
    Thats what I was thinking...
    A pic would help....
    Delta T13120 Classic Single Handle Tub Trim Chrome
    Dec 2007
    See page 5 of the 1300 series instructions at this link.
    Instruction booklet
    Thanks!! problem resolved!!!
