Results 1 to 11 of 11
Thread: Quasar toilet (WC) - need tank
    Default Quasar toilet (WC) - need tank
    HI All,
    I have a Quasar water closet and need a tank for it. Can anyone tell me who makes it and if there is any way to find out what tanks will fit it?
    It was left over from the initial construction of the house. I am putting a bath in the basement and would like to save a few bucks by using the WC if I can find a tank that will fit.
    Thanks in advance.
    Dec 2007
    I believe it is an Am. Std. toilet...
    Probably better used as a planter...
    Or, dumpster filling...
    Try these as model numbers 01915/01925
    Yakima WA
    My guess is that this was a builder special from a box store and no parts are available. Of course if you really feel saving a few dollars on the most frequently used appliance in your home is worth it, just find any old tank in the dump and buy a big roll of duct tape. Yeah, you better get a mop and plunger too. On the other hand, buy a Toto and your good for the next 40 years although you might have to spend $10 every 10 or 15 years for a new flapper and fill valve, but they are available anywhere.
    Hey, thanks for all the sarcasm. It's a big help. BTW, what happens to a toilet bowl that it wouldn't last forty years? Or, in other words, why would one porcelain bowl last forty years and another won't?
    Default tank
    Measure the distance between the anchoring bolts, and find a tank with that dimension. Unless it is so thick that it either hits the back wall or interferes with the seat in front, it should fit.
    Plumber jimbo's Avatar
    I am not familiar with the brand....sounds like a no-name.
    In general, toilets are a set. Tanks and bowls from different manufacturers or different models even, are usually not considered interchangeable. Especially if you don't know if you are dealing with a 1.28, a 1.6, a 3.5 or what?
    In theory, you may find a tank which hooks up and might work. You will NOT find any information on cut sheets, or much help from salespeople anywhere, in this search.
    Union plumber/pipefitter-self employed Garydaplummer's Avatar
    Jan 2008
    Mechanicsburg, PA
    Smile Contact AS
    Redwood's right with the numbers, it's listed as an IAPMO approved 1.6 gallon toilet manufactured by American Standard with those listing numbers. Try contacting AS, but they do not make this model any longer. Good luck.
    [QUOTE=Garydaplummer;165649]Redwood's right with the numbers, it's listed as an IAPMO approved 1.6 gallon toilet manufactured by American Standard with those listing numbers. Try contacting AS, but they do not make this model any longer. Good luck.[/QUOTE
    Thanks for your help. I thought of taking a rubbing of the bolt and hole pattern to see if I could find a tank to match.
    I am sure it's a 1.6. It's what all the tanks were when we built the house in '99. Did they even have 1.28's then?
    Jan 2008
    Mechanicsburg, PA
    Talking Try this place
    Look inside the tank and see if you can find the model number stamped in. Then take a look at this place, they may have or be able to get you what you need. Do make sure you're not spending more on this "vintage" toilet tank than a new replacement toilet would cost you.
    www.toilettanklids.com
    Dec 2007
    I figure with American Standard a toilet has to be pretty damn bad for them to discontinue it...
    Look at the lemons they keep reinventing...
    The Champion # 7,947,425
    The Cadet " 57,853....
    Okay so I listed next years model numbers...
