Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
Thread: pump wont come on
  1. #16
    Previous member
    Jul 2005
    Riverview, Fl.
    What I am trying to do is help you troubleshoot the problem. The fact that you run things throughout the day doesn't tell me anything. Watching the water level in the well while someone else turns on a lot of water will tell you if the level of water in the well goes down to the pump or not.
    bob...
  2. #17
    DIY Senior Member WV Hillbilly's Avatar
    Aug 2008
    WV
    Are you 100 % sure the pump is down in the well casing ?
  3. #18
    The well is 110 ft. deep its a little difficult to watch the water levels.
  4. #19
    Sorry Hillbilly didnt mean to forget you. Yes the pump is in the well casing.
  5. #20
    Aug 2008
    WV
    You have a confusing problem .
    1- You said in your 1st post that when the pressure drops to 30 the switch closes but the pump doesn't come on . When this happens is the pump not running or is the pump running but not pumping water ? If you are near the casing you can usually hear the pump running if it is running . If the pump isn't running with the switch closed , either electricity isn't getting from the pressure switch to the pump motor or the motor is kicked out on its internal thermal overload switch or the motor itself is going bad . If the pump is running but not pumping water when the switch closes at 30 pounds then it's not an electricial problem unless it's an intermitent problem .
  6. #21
    Previous member sammyhydro11's Avatar
    Dec 2006
    Massachusetts
    If the contacts aren't closing,you either have a bad pressure switch or the nipple that the pressure switch threads into is clogged..
    sammy
    www.tylerwellandpump.com
  7. #22
    It could be a bad wire nut connection or loose screw on one of the wires in the switch if the points are closed and the pump doesn't start.
  8. #23
    OK, called in the professionals, the guy who installed everything several years ago used 15 to 20 feet pieces of pipe and then connected them together for over 110 feet instead of one large roll of pipe. These fittings were starting to rust thus causing leaks in between, causing backflow and not allowing enough pressure to make the points close. They replaced all piping and installed a new check valve , old check valve was built inside the pump, said they had never seen this. Check valve was not bad but with it built in pump they thought it best to install one above pump just in case it would ever go bad. Good news is I did not have to go outside at 5:00 am to turn water on in 12 degree weather, Yah!
  9. #24
    Red face
    Thanks to all who gave advice, hope that by posting the final solution someone else can use this info to help them. Must have been mistaken about the points closing and pump not coming on, unless at that time there was just enough pressure to try but not enough to complete the task. Oh well, thanks again to everyone.
  10. #25
    Previous member
    Jul 2005
    Riverview, Fl.
    I don't know where these guys are from, but having the check valve built into the pump end is the rule not the exception.
    bob...
  11. #26
    And if their threaded fittings in the drop pipe were leaking then they didn't use tape of dope and tighten them correctly 15 or so years ago. But that would not cause you to have no water, so I'm not sure your problem isn't hiding right now but, why did they pull the pump to find these loose fittings when they should hav efound out why the pump wouldn't run and that is usually something not requiring the pump to be pulled unless ther was power to the well but the pump wasn't running. I'd find a new pump guy next time.
  12. #27
    These guys were not the original installers. Said where the pipes inside well casing was leaking was causing water to drain back from points, therefore no pressure built up to turn points on so once we used all of the water in the tank, pump wasnt coming on.
  13. #28
    Aug 2008
    WV
    Earlier in the thread someone asked you if you had the pressure switch with the low pressure cutoff . The one with the lever you manually turn on to make the pump run . You said yes . They suggested you try another switch & you said you did & had the same problem . Was the other switch you tried like the first one with the low pressure cutoff & lever ? If you had used a regular switch the pump would have run & you would have had water even with the leaks in the fittings in the well pipe . Your pump would have cycled more than necessary so it's good you got those leaks fixed .
  14. #29
    Quote Originally Posted by jrmcmil View Post
    Here's how it works, the pressure switch points close when the water pressure falls to the cut in setting, I.E. 30/50 switch settings, the 30 psi. When the points close the pump comes on, now these guys say the joints in the drop pipe were leaking, that means that the pump keeps running and can not build up enough pressure (50 psi) to open the points and shut the pump off but... if it did shut off, the pressure tank allows the water to go back down the well through the leaking fittings and the pressure falls and the points of the switch close and the pump comes on and the process repeats.
    Now you said you didn't have any water because the points didn't close. Leaking fittings don't cause that, they cause the points to close unless you have a check valve at the pressure tank.
