Results 1 to 7 of 7
Thread: Should I try to clean the A/C coils myself?
    DIY Junior Member riker1384's Avatar
    Sep 2006
    Virginia
    Default Should I try to clean the A/C coils myself?
    The coils on the indoor part of our air-conditioning/heat-pump system are dirty. Is this something I should try myself? I'm any sort of professional. Some sites say I could do it myself, some say it should be left to experts.
    If you do it yourself, you may want to invest in a fin comb to straighten any bent fins.
    Computer Programmer Bill Arden's Avatar
    Sep 2006
    MN, USA
    A garden hose works well, but you have to make sure to shoot straight in or it will bend fins.
    Important note – I don’t know man made laws, just laws of physics
    Disclaimer: I'm a big fan of Darwin awards.
    DIY Senior Member burleymike's Avatar
    Nov 2008
    Idaho
    I usually use a pump up sprayer with some coil cleaner. You will be just fine with just plain water. If you don't have a pump sprayer you can use the garden hose just dont hit it with a lot of water. You don't want to get the blower or anything else wet. Also make sure your condensate drain does not plug up with the crud.
    DIY Hillbilly Southern Man's Avatar
    Jun 2008
    North Carolina
    This is an inside evaporator guys, not the outside condenser. A garden house will create a wet mess.
    Most manufacturer's will tell you what type of brush to use to clean the coils dry. If you can't locate the manual that came with the unit then Google "condenser brush" and looking at your unit and accessibility figure out which type will work best for you. Keep the shop vac going to catch the dust because it's very fine and irritating.
    Dec 2007
    I use the same method Burley Mike described.
    Quote Originally Posted by SothernMan
    Garden House?
    I'll assume that you added extra letters to "hose"
    Maybe an engineer would make a mess with a hose, but, most of us would know to be careful and make sure the condensate drain is not plugged.
    Jun 2008
    North Carolina
    Yes I meant garden hose, not house. A garden hose would create quite a mess inside a residential house, but would probably be manageable inside a garden house. Although I have yet to see a garden house with AC.
    I appreciate your exactness kind sir.
