Page 1 of 3 123 LastLast
Results 1 to 15 of 37
Thread: radiant heating
    DIY Junior Member fozzy12's Avatar
    Jan 2008
    North of Detroit, MI
    Default radiant heating
    I am building a 30 x 36 garage. It's 2 x 6 construction with attic trusses. I end up with an 18 x 30 room upstairs. I am putting radiant tubing in the slab and also under the second floor sheeting. I bought the system from a supplier in VT. They are well known. I need a hot water heater that has an output BTU rating of 40K. That is figured by input BTU times efficiency. When I looked around the big box stores, they don't have anything. I checked Rheem and Ruud and they have one although it's a 75 gallon unit. When I called my local plumbing supply, they told me what I was doing wasn't legal. Said in Michigan you aren't allowed to do that with a water heater. This is a closed system, there is no water in the garage. It is not going to be used for anything else. They tell me I need a real boiler to do this. The company disagrees. I have a phone call into the inspector now to figure out what to do. Any thoughts out there?
    Eric
    Using the proper backflow preventers and safety features, it would probably work. Personal opinion, a WH is not designed for continuous use like what would happen during a heating season and you'll probably wear the thing out. A commercial unit might be rated for a higher duty cycle, but again, a boiler is designed to run continuously, a WH is not, so your life expectancy may be low.
    Jul 2008
    S. Maine
    Why would you want to go to all the expense and effort of installing radiant heat just to use an inefficient tank heater to drive it? Heating 40 gallons of water or more makes no sense from an efficiency standpoint at all. Do yourself a favor and find a high efficiency Mod Con boiler.
    I did exactly what you are proposing.
    I had a 18 x 30 building attached to my 30 x 30 gas heated shop.
    In the 18 x 30 building I have 2 zones with approx 200 ft per zone.
    It is heated with 2 40 gallon electric water heaters.
    The first year I used only one water heater but I found when the tempetures got to -40 for a week at a time the one 40 gallon was working all the time.
    Now with the second unit dumping into the first they are off most of the time.
    Shop is warm all the time.
    It is illegel around here I believe as well but it has been working flawless.
    I went this way only because I wanted a "ignition free " area to paint in.
    Don't be turned off your idea it does work. ( 5 yrs now )
    I was told by my electrical inspector that the equipment needs to be UL listed for heating service. This was in MN.
    DIY Member enosez's Avatar
    Jan 2007
    Long Island NY
    [QUOTE=Paso One;166293]I did exactly what you are proposing.
    What water temp are you running through your zones?
    And are you using a manifold?
    Here in NY it would cost a fortune to running anything electric let alone during a cold spell.
    I considered it also for a 900 square foot garage but in the end operating costs made it cheaper to go with a boiler.
    Jul 2008
    S. Maine
    Here's a pile of other issues also. The slab will want water temps around 85 degrees, the staple up around 160 or perhaps more depending on the substrate and floor coverings. Running an electric water heater at those temperatures will cost a fortune and require a mixing valve for the slab heat. I've seen this done several times before and it has never worked out. The water tank is usually swapped for a boiler of some sort within two years.
    [QUOTE=enosez;167041]
    Quote Originally Posted by Paso One View Post
    I have 2 zones (see pic) temp tonight is about 130 degrees outside tempature is 20 degree f
    Jul 2008
    S. Maine
    If you are running 130 through the slab your cement will crack, powder and fail within a couple of years. Never more than 95 degrees maximum.
    Jan 2007
    Long Island NY
    If thats daylight coming through the outside perimeter wall , I'd think about putting insulation there. (Heat loss to outside)
    Also all of your loops are uniform, without an exterior zone loop which is usually closer together since more heat loss is at exterior walls.
    The outside "daylite" you see is actually the aluminum air foil going up the wall.
    The concrete hasn't cracked yet But concrete in this area always cracks so It is going to happen anyway. No sign of powerdering at all. ( 5th winter )
    My water tank is set at 130 degrees but I'm sure it is less going thru the slab.
    I'll try it set lower. I park a bobcat in the area so it heats the steel and is nice and toasty when needed.
    This is the first I heard of the max 95 in concrete.
    Around here people heat the driveway to melt the snow so perimeter heating is a moot point. ( my loop melts outside threshold )
    Sep 2006
    MN, USA
    Quote Originally Posted by nhmaster View Post
    Because it's cheep and a lot easier to upgrade in the future.
    Electric boilers have gotten cheaper so using a hot water heater is not saving very much.
    Important note – I don’t know man made laws, just laws of physics
    Dec 2006
    If the "well-kinown supplier in vermont" is who I think it is, you need to STOP what you're doing. Those guys are notorious for half-assed advice, badly designed systems, they're just very good at "image control" on the internet.
    Go to the forums at heatinghelp.com, do a search on that forum for the supplier's name. Stick around for a bit, over there, lotsa good info on designing a proper radiant system. Other good sources: radiant panel association, radnet, warmly yours.
    Master Plumber Mark:
    do not hit your thumb...
    __________________
    Jul 2008
    S. Maine
    Having designed and installed more radiant systems than I can even begin to recall in the past 25 years or so, it makes me scratch my head when I read threads like this. There is always someone that can and will justify almost any half assed combination for either price or expediancy reasons. Just because you have been running 130 degrees for 5 years now without a catastrophic failure you think that it must be ok and those of us that design and install for a living (and back it up) must be wrong and or overly cautious. So keep on keeping on, and when the you know what hits the fan be sure and not bother to tell those of us who will say " I told you so"
    Thumbs up
    You are always to the point..I for one appreciate your inpu on here...Thank u..
  1. Radiant Heating
    By tingeyplumbing in forum Plumbing Forum Discussion & Blog
    Last Post: 09-28-2012, 06:31 PM
  2. Radiant floor Heating - Pex, etc.
    By chuck b in forum Plumbing Forum Discussion & Blog
    Last Post: 02-16-2011, 02:56 PM
  3. will this for radiant heating
    By rrekih in forum HVAC Heating & Cooling
    Last Post: 02-06-2010, 08:15 PM
  4. Radiant Heating
    By Oliver in forum Plumbing Forum Discussion & Blog
    Last Post: 11-26-2005, 10:21 AM
  5. Radiant Heating
    By John in forum Plumbing Forum Discussion & Blog
    Last Post: 01-24-2005, 06:02 AM
