Thread: GFI weird issue
    DIY Senior Member Jeff1's Avatar
    May 2006
    So Cal
    Question GFI weird issue
    We hired someone to add outlets in the front yard. This is a new circuit with a GFI on the house leading to 2 boxes in the yard. When the GFI tripped (a fixture got wet), I reset it and nothing worked. I got out my handy tester and it showed hot and ground reversed. I looked in the boxes (with the breaker turned off of course) and saw nothing obviously wired incorrectly. When the power was turned back on and the GFI reset, everything worked. Since then, if the GFI trips, I need to reset it twice to get the line working again.
    What could cause this? I'm already looking at why it trips, but I'd like to know what would cause it to need to be reset a couple times.
    Thanks in advance.
    Plumber jimbo's Avatar
    A "loophole" in many of the little plug-in outlet testers is that they report and OPEN NEUTRAL as hot/ground reversed. Look for a loose connection on a neutral wire somewhere.
    May 2006
    So Cal
    Thanks. I'll look into it.
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Quote Originally Posted by Jeff1 View Post
    It will soon fail.
    BTW, if you run a 120v test lamp from the GFI short slot to a known good ground it should trip.
