Results 1 to 5 of 5
Thread: Grohe rough-in valve, but shower head only
    DIY Junior Member
    Jun 2008
    so cal
    Default Grohe rough-in valve, but shower head only
    Hey everyone, I have a Grohe 4-port rough-in valve:
    Name:  grohe 4-port EF with duel connection stops.jpg
    I installed one a couple years ago in another bathroom and ended up capping the top and putting an ell from the bottom, which then split off to the tub spout and to the shower head - it's working great, no pesky drips, etc.
    Now we are getting to the master bathroom which has only a shower head (3/4 bathroom) with no tub.
    Here's my question, should we cap the bottom and run the top port to the shower head? ...or would you recommend an alternate approach.
    Any help would be appreciated, thanks!
    Default valve
    That is really the only sensible approach, but going back to the other valve. How did you split off to the tub and shower? Normally it is only done with a "twin ell" in order to prevent water running from the shower head when filling the tub.
    DIY Junior Member
    Jun 2008
    so cal
    yes, it was a twin ell, dropped the supply from the grohe down to the forward connection, back connection went up to the shower and front went to the spout:
    DIY Junior Member
    Jun 2008
    so cal
    Thanks for the help hj!!
    Default twin ell
    I was curious because your original description implied you did it differently and I wondered how you could have gotten lucky.
