I have a totally broken all the way around toilet flange. It broke off inside the pipe which is only a 3 inch pvc. So the flange is not usable at all. Of course, its on the basement floor which is of course not level, which is why it broke. My question, do i risk cutting out the old flange which is about 3 inches below the floor surface on the inside of the 3 inch pvc pipe and glued in there very nicely. I worry that I will break the 3 inch pvc pipe that is running under ground in the cement floor. Or should I just scrap it all, dig it all up, and install the correct size discharge pipe. I could also take the asy way out and install a 3 inch "repair" flange inside the existing broken flange, but that will really cut down the diameter of the pipe for the waste. It was already backing up before quite a bit. Thanks.
