Results 1 to 12 of 12
Thread: Adjusting receptacles due to new tile
    DIY Hillbilly Southern Man's Avatar
    Jun 2008
    North Carolina
    Default Adjusting receptacles due to new tile
    How do I adjust this? An extender box does not fit.
    Jun 2007
    NY State, USA
    An Arlington BE1 box extender will fit that application.
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Quote Originally Posted by Speedy Petey View Post
    Since the tile is fireproof can't he just use standoffs?
    Jun 2008
    North Carolina
    Those won't work. The edge of the tile goes over the sides of the box underneath.
    Jun 2008
    North Carolina
    Quote Originally Posted by Thatguy View Post
    Can I get them at the local big box? I already looked for something like that at Slowes with no luck.
    Jun 2007
    NY State, USA
    Quote Originally Posted by Southern Man View Post
    Then have your tile guy come back and fix his screw up. The tile should NOT be past the box edge.
    The BE1's are smaller than the box and are tapered. They might fit. Unless the tile is considerably inside the box they usually do.
    Combustible or not, I like to use them.
    DIY Member B2CHR's Avatar
    Jul 2008
    Central NC
    Yea tile job messed up to start with. I always run my tile down to the outlet mounting screw so the outlet will lay on top of the tile. In this case I would cut a small piece of tile to slip up under the outlet "wings" and tighten the outlet down on them and install a larger face plate.
    DIY Member rayh78's Avatar
    Sep 2008
    Virginia
    look at
    www.rd.com/familyhandyman/content/19468/
    or buy the spacers made for this at H Depot, think lowes has to.
    Jun 2008
    North Carolina
    He took 6 days for a 3 day job and I don't want to clean up after him a 7th time. Besides the tile is a "crackled" finish and would probably fall apart if he tried to dry cut them.
    I'd like to use the extenders too, and bought a few for where I can fit them without cutting them all up.
    Jun 2008
    North Carolina
    Quote Originally Posted by rayh78 View Post
    look at
    Found 'em at Depo' this morning, hiding on a bottom shelf. Thanks!
    Jun 2008
    North Carolina
    Spacers worked great. They are rubbery plastic and connect together like legos. I had to use between 5 and 9 layers, depending on the locations.
    Aug 2008
    MD
    Universal spacers:
    a 1/4" copper tube and tubing cutter and you cut to length on the job-
    or, 1/4" plastic humidifier pipe, you cut with knife, same deal-
    You can also wrap your own spacer with coat hanger wire but it strongly resists this treatment. If you have a gas flame, heating the wire red hot and letting it cool takes the argument out of it.
    Don't forget your long 6-32 screws.
