What is this thing? See picture please!
Chris Poco
My landlord came with a box of copper things. Some are labelled "Sioux Chief Mini-Rester", and a Google search brought me here. What an informative link it is. Thank you Terry!
The other copper thing is still a mystery. See the attached jpg picture.
What is this? And is there a similar write up for this here or anywhere else?
Thank you for any help!
Chris Poco
thing
It could be a refrigerant in line filter/dryer, or depending on what's in it, it could be some type of shock absorber, but it is not like any I have ever seen if that is the case.
Master Plumber Mark
www.weilhammerplumbing.com
looks like
looks like a sensor or probe
looking at the left end it appears to have a probe end on it...
something that went into a port on either a refirgeration system
or into a port on a commercial hot water heater
both would be in series with some sort of aquastat which is connected to that greener end...
is their a prize or something for the guy that guesses this right???
Chris Poco
Picture with closer look at ends
Prize for the one who guesses right? How about the thing itself?
Problem is I won't know who made the "right" guess since I surely don't know what it is ;)
Further info: Both ends appear to be sealed, and when shaken, the inside of the bulb gives off sounds as if it contained beads, sand, or some such. Not loudly though, I have to really put my ear to it to hear.
Thanks Mark, Mike, and hj for your attempts so far!
See picture attached for more details on the ends.
Chris Poco
I Think hj's Got It!
Congratulations hj ! I've checked Grrainger's web site and found the item #6X526 exactly as you said.
Dryer,Liquid Line
Heavy Duty Liquid Line Dryer, R 12 Capacity 1 Ton, R 22 Capacity 2 Tons, R 12 Water Capacity @ 125 Degrees F 84 Drops, @ 75 Degrees F 99 Drops, R 22 Water Capacity @ 125 Degrees F 75 Drops, @ 75 Degrees F 90 Drops, Connecting Tube Inlet ID 1/4 Inch, Connecting Tube Inlet OD 5/16 Inch, Connecting Tube Outlet ID 0.127, 0.130 Inches, Connecting Tube Outlet OD 7/32, 5/16 Inches, Shell Diameter 1 3/16 Inches, Overall Length 9 3/4 Inches
So, send me your mailing address and I'll ship this unit to you as your prize if you want it! Just let me know. Thank you everyone!
