Results 1 to 4 of 4
Thread: Taco ESP Zone valves
    Default Taco ESP Zone valves
    Hiyas,
    My home has a gas furnace with forced hot water base boards. It's relatively new 2003.
    The problem is it has Taco esp zone valves 3 zones all have been replaced at least once.
    The HVAC company that did the original work replaced them saying Taco improved the motor. Well I have 2 burned out motors that can't turn the ball valve.
    What should I do replace them with the same or get a new valve system?
    Thanks in advance
    Master Plumber nhmaster's Avatar
    Jul 2008
    S. Maine
    you probably have too many zone valves on a transformer, or the transformer does not have enough amperage. The valves themselves are quite dependable.
    There are 3 zones and the power supply is from taco also it has 4 zone capability and is 24vac. After some research they have discontinued the ESP and are now called EBV. Same concept with a better motor from what I can tell.
    Taco is sending me 2 new motors for free so I hope they work.
    Btw I live in southern Maine. Can you recommend a good company if I ever need work done on my furnace. I kinda have had it with the people who installed it hence taking matters into my own hands.
    Jul 2008
    S. Maine
    Dunno, Maine's a big place. Where ?
