Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Ideas on how to get a 150# water heater into the attic?
    DIY Junior Member ForrestGump's Avatar
    May 2008
    Friendswood, Tx
    Default Ideas on how to get a 150# water heater into the attic?
    How do you pros go about getting a 50 gal water heater thats weighs 150lbs into a attic?
    I have a staircase inside a 1 story house in the hallway and the water heater is 3 feet from attic opening.
    I thought of getting a come along and hook it to the new water heater and the rafters.
    Would it be ok to take 2 - 3/4 galvanized T's connected to the hot and cold nipples with a large bolt running though the T's so I can hook the come along hook to? Would this damage the tank?
    I use a copper flex connector between the two pipe nipples and just lift it up by hand.
    150 pounds isn't very much weight.
    Feb 2005
    Talking what I use....
    Generally when I got a really mean water heater
    to install I let my apprentice do the lifting....LOL
    and if it is extra extra mean, then I hire someone from
    manpower for the day....to help the apprentice do the lifting....
    May 2008
    Friendswood, Tx
    Thanks Terry for the fast response!
    So just a copper flex line is strong enough to hold it on the come along?
    Check out my pictures here of what I have setup so far: http://jsmjd.smugmug.com/gallery/626...95597388_os9ng
    password = 123
    I'm not going to guarantee that.
    I do it. But then I do lots of things that can't be done too.
    Lot's of times I just use a flex that is going to be tossed anyway.
    I like the fact that there is some give to it, and that it makes a nice handle for my hand.
    If you can have someone below helping a bit, that's even better.
    Default heater
    Use a rope and make a barrel sling under and around the heater. Then hook the come a long to the sling.
    Dec 2007
    I'm sooooooooooo glad we have basements around here...
    Quote Originally Posted by ForrestGump View Post
    Sounds like a perfect time to convert to a tankless water heater!
    Plumber Cass's Avatar
    Nov 2005
    I would definitely use HJs sling method when lowering the old heater...
    I would not trust those old nipples to hold...they might but...
    I wouldn't want to be the guy on the bottom if they didn't.
    May 2008
    Friendswood, Tx
    Thanks everyone for the help. I am going to buy GE 12yr 50gal water heater today at HD and install it on Saturday.
    I will try to make a YouTube video of me getting it into the attic and post the link to it here next week.
    Default heater
    I'm glad we have VERY few basements, and VERY few heaters in the attic around here. It could end up like a supply house years ago. They had a shaft where they used a hoist to lift items up to the higher levels. A new guy was getting a cast iron bathtub down from the third floor and tied the cable through the wooden slats at the end, instead of through the waste and overflow holes. When the staples pulled out and the tub hit the clay tile pipe and fittings in the basement, it sounded like an atomic bomb had gone off. There wasn't much of the tub's enameled finish left either.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Default Water heater in attic
    Now ! !
    Would be a "very good" time to install that new drain pan under that new heater run the 1" pvc across the attic and down the
    outside of the house, ! !
    Before you wake up some morning taking a shower in bed ! !
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    If I had a gas WH, I'd probably install a WAGS valve when replacing it...it shuts both the gas and water off if it starts to leak. www.wagsvalve.com No power, it's all mechanical. Uses the same type of actuator that triggers the inflation of safety floatation vests used on airplanes - all it needs is to get wet and a spring and switch does the rest.
    DIY Senior Member seaneys's Avatar
    May 2007
    Chicago Suburbs
    Quote Originally Posted by Redwood View Post
    Same here. I would hate to think of putting anything like that above my head.
    Most water heaters around here are in the garage.
    Thank goodness.
