Hello all,
Would really appreciate some insight on my concern. Recently bought a house(1yr ago) that has a well. Woke up this morning to no water. Had a "Well service" come out, they replaced the well pump and misc stuff like the gauge on tank, pressure switch etc.
They upgraded the pump from a existing 1/2 to a 3/4 hpwr pump (4" goulds)....all went well until they finished up, chlorinated the well and began to run the pump thru a garden house to run the water until it ran clear(I also have a septic). The water volume was very good.
I wasnt entirely paying attention to the time but it must have been running non-stop for 40-60minutes before the water slowed and then stopped. I concluded with their help the well was run dry.
Turned the power off, waited 30 minutes or so and had water again.
My question is now do I have a bigger problem with the well? is this normal? is this a low yielding well that I need to be worried about. until now, I never had any "water" trouble at all.
other stuff I know about the well from the guys
165ft well
pump at 150ft
after install, they said I was pumping 15gal per min.
Thanks in advance!!!
165ft well
pump at 150ft
