Results 1 to 2 of 2
Thread: Hand pump for cistern
    DIY Junior Member rcramp's Avatar
    Oct 2008
    Washington
    Default Hand pump for cistern
    Hello,
    I have a cistern that is buried and I want to hand pump water from 5 feet below ground level to 25 feet above for a tank that I want to use for irrigation/flushing.
    I realize that this would be too far for a 'shallow well' hand pump if the pump was at the highest level but is it different because the pump is lifting 5 feet and pushing up 25 feet? (25 feet horizontal as well)
    What is the best hand pump for this application. I want 5 gal/min and want it to be hand/mechanical. Is this possible?
    thank you
    In the Trades maintenanceguy's Avatar
    Aug 2008
    Pennsylvania
    A hand pump can push as far as your arm is strong enough. It just can't pull more than about 25-27 feet. This is because atmospheric pressure is just about the same as the pressure at the bottom of a column of water 30' tall.
    Once you have a column of water that's almost 30' tall, atmospheric pressure can't lift the water any higher.
    As for 5GPM, with a head pressure of 30', (that's 5' pulling and 25' pushing), A 1/4hp pump would work. A person supposedly can produce around 100 Watts continuously, a HP is 746 Watts so if you're in good shape, you could probably pump 2 to 2.5 GPM.
    An Olympian might pump 5GPM for the first minute.
