Sounds like what you have there is a reverse return set up which is actually just fine. The feed goes out to the convectors and the convector returns are tied into a common return. If he's been having problems with insufficient heat it's probably because there is either air in the convectors, the return or the convectors may be somewhat plugged up. I don't think I'd go to the toruble of loop piping besides which there is too much restriction through the convectors to get away with it.
