Water (well, nothing) flows uphill without help, so to do it you'd need to dig a pit for a tank and a pump, and then you might as well just break the slab to do it right and let gravity do it for you. If the line the washer drain goes into isn't 2", then you have to find the main line or one at least 2" to meet code (drain pipe is inside diameter).
