Results 1 to 7 of 7
Thread: Water Jetting the main sewer line?
    Electrical Engineer jdf405's Avatar
    Jan 2008
    Los Angeles Area
    Unhappy Water Jetting the main sewer line?
    Hi All,
    Last night I discovered that my main line to the street is clogged (the joys of sewage in the bathtub... ). This morning I had the plumber come out and he snaked it through fairly easily. My main is 3" and my house is about 55 years old in southern California (I'm guessing clay pipe).
    For another $100 they sold me on coming back to "water jet" the line and this comes with a camera view. I decided to go for it because I felt it was worth $100 to see what's going on down there. Is the whole water jet thing really worth it aside from the camera view?
    Jonathan
    Plumber patrick88's Avatar
    Sep 2007
    Webster Ma.
    That is a good price for the Jetting.
    That is also a good price for the camera.
    The camera will show you any problems you may have like cracks or bellies. It can be worth the money to jet the line if you have roots in the line. If they are using the larger jetting machine line a trailor jet it will cut out any roots (4,000 psi) . The mini jet will not do a lot for your main. Unless you have a lot of grease or other soft stuff in your main.
    I'm just starting to work with an old friend of mine to bring solar electric and hot water systems, wind turbines, Flex Fuel Boilers, batteries, hydroponic gardening, books, pellet grills and more. Also the parts for DIY installation.
    Jan 2008
    Los Angeles Area
    Thanks for the info. Hopefully they'll use the high pressure one! Eitherway, the info from the camera will be educational.
    I guess the whole budget is as follows:
    $175 for roto-route
    $75 for climbing on roof
    $29 for equipment
    $100 for jet (optional)
    Jonathan
    In the Trades maintenanceguy's Avatar
    Aug 2008
    Pennsylvania
    Around here the big outfits are getting a lot more than that for drain service.
    The water jet and camera is a $100 sales tool to show you that you need more expensive work to be done. But that's not necessarily bad, if you do need more work done, it's good to know. It's good to know before it's an emergency so you can get a couple of estimates and budget to have it done.
    Ask for a copy of the video. Then, if you decide you don't want to do it right away, you can show it to the next guy for a second opinion.
    Sep 2007
    Webster Ma.
    I was the next guy for one of those videos before. The last guy did not see the 12" X 3" crack in the pipe. He got the 2 minor root balls, but missed the cause of the call. Sewer water leaking back thru the foundation wall.
    Default camera
    When the camera's eye leaves the house you may be able to see where your cleanout is and dig it up for use the next time it plugs up.
